(1) Prepped rudder frame and ribs for primer. Used acetone to wipe off markings on aluminum, roughed the surface with a scotch brite pad,and wiped down with a clean cloth. (2) Set up an area to use for priming the airframe parts. (3) Primed the rudder frame and ribs.
